Présentations
artemisclark
Présentations
Message par artemisclark »
Portable Air Conditioner Vs Personal Air Conditioner Which Do You Choose?
Today, about 87% of U.S. homes have air conditioning. That is proof that the air-conditioner has clearly affirmed its position in the market today.
Check This Out: The King Live
We are dependent on it; we use it continuously, almost every day, especially in the hot summer. In this article, we will show you the comparison of two popular types of air conditioner which are a portable air-conditioner and personal air conditioner. The representative product for each type will be the top reviewed product on Amazon.com.
HomeLabs 14,000 BTU Portable Air Conditioner - Quiet AC Cools Rooms 550 to 700 Sq. Ft. - Includes Remote Control and 100 Pint Dehumidifier Function
Portable, Quiet, Energy-Efficient Air Conditioner
It is equipped with an automatic vertical swing function which can perfectly cool rooms that are 550 to 700 square feet in size. It can distribute airflow throughout the room without making any noises.
Easy to install, no heavy window unit to lift
It measures 17.9 x 15 x 30.7 inches and comes with wheels for convenient moving. You simply move this air conditioner to any room that has a window; after that, you attach the hose and the window slide adapter and then plug in the power supply, and the product will start cooling. Due to its compact design, it can be stored anyplace whenever you do not need to use it.
Built-in dehumidifier function
Different from traditional dehumidifiers, it can expel moist hot air through the exhaust hose thereby cooling your room and not pushing excess heat into the room. However, it needs a drain hose because it does not have a built-in drain tank like other products.
Washable air filter
The washable filter is easy to clean and you need to clean it once every two weeks. If you forget and the air filter becomes dirty, the filter indicator light will illuminate to remind you.
Intuitive remote control and digital display
You can set your desired temperature, change the cooling modes or fan speed, and activate the eco-friendly sleep function with ease by using the remote.
This Content: TOP product evaluated on TheKingLive.com
Personal Air Conditioner, Air Personal Space Cooler with Humidifier and Air Purifier USB Mini Portable Air Conditioner
New Space Air Conditioner
This is a 3-in-1 air conditioner with a compact and portable design. Due to the humidifier and air purification features with the classic swamp cooler technology, it draws in hot air and passes it through a wet filter, then exits out the cool side, which makes us feel comfortable and refreshing.
Energy Efficient & Eco-friendly
The special thing about this product is that it uses a USB power plug in order to be more economical but still provides high effects.
Easy-fill Water Tank
That means that this product is easy to operate. You just fill it with water, then plug it into a USB port or power bank and the fan will begin to blow. With many advantages such as 8-hour built-in water tank, ultra-quiet operation, and Freon-free cooling, it will not disappoint you.
HUMIDIFICATION & COOLING AIR
This amazing product also sprays continually for 4-6 hours thanks to a large 420ml water tank, add drops of your favorite essential oil into water, increase the air humidity, purify the air, and moisturize your skin. If the weather is extremely hot, you can add some ice to the water to make the air fresher and cooler.
MULTI-FUNCTION
In the latest model, there is a drip tray to catch excess water for reusing and avoiding dripping wet spots on your desktop.
See Also: Save Money With the List of Products Tested on Thekinglive.com
Conclusion
Based on the name, we can recognize easily that a personal air conditioner is suitable for personal use, especially for office workers who need to be relaxed for many hours of continuous work. This product is also suitable for those who love the environment and save energy thanks to its superior features. Alternatively, a portable air conditioner is used for a completely different purpose; it serves more people, cooling a larger space, so there is a higher cost for the product as well as higher electricity costs. All in all, these both have the best Amazon product reviews; you just need to determine your intended use then choose the best product.
Modifié en dernier par artemisclark le mardi 23 janv. - 5:24, modifié 5 fois.
Re: Présentations
t'as des popos avec ou sans rehausse à retaper à tout les prix, mais installer une rehausse prés coup c un peut plus compliqué du aux renforts de caisse dans le toit.
beaucoup de spots surf ont des barres à 2m de haut, faut y penser aussi.
essence ou diesel ? question à 1000 balles. le cout du déplacement est en faveur au diésel donc à toi de voir.
courage pour tes recherches et à bientôt,
x@v :wink:
f-666
Re: Présentations
Message par f-666 »
Tout va dépendre de te besoin réel
Vitesse de déplacement, camping sauvage ou pas
Niveau que tu veux atteindre en restauration etc
Jeanjj
Re: Présentations
Message par Jeanjj »
Pour les toits neufs, tu peux te renseigner là,
Mais ça chiffre fort...
